heat-shrink cable ends
Started by Ed G., June 11, 2005, 11:15:16 PM
Ed G.
I remember seeing some cables before where the outer covering was just heat-shrink. I wanted to make some really short cables with 90 degree ends for a pedalboard and I thought that might be cool, especially if I could save some bucks instead of getting switchcraft ends. Anyone know who sells these ends?
brett
Hi.  I buy those metal-with-a-spring plugs, and some 3/8" or 10mm heatshrink.  The heatshrink is a bit small, so first I stretch it (to about 1/2 inch) by slipping it over the end of my pointed nose pliers and opening them.  Make up the plug as usual, slip on the heatshrink, and use a hot air gun for a great lead.  I reckon my leads are better than commercial quality.
hope that helps. cheers
Brett Robinson
Ed G.
Thanks for the reply, Brett. I'm not familiar with the metal and spring plugs. Does Mouser carry that? I want to wire up my pedalboard and I figure this might be more economical and neater.
