Sonic Distortion problem
Started by wui223, January 22, 2007, 05:23:07 PM
wui223
I got an Ibanez Sonic Distortion. When i press on, the effect sound is OK. When in bypass mode, no clean sound coming out but some blend of distortion sound. Anyone could suggest a possible remedy ?
Could i change it to True Bypass ?
jonathan perez
no, you couldnt change it to true bypass.
any mods done?
MartyMart
jonathan perez
oooh yeah!!!!!
i thought so!
whoops  ;)
i think i was sorta zoned out when i typed that...im pretty sure i meant "i wouldnt do it, it sounds fine"
rocket
Try to find a suitable schematic ( any 9-series pedal will do)  and look how the bypass works, it seems that the fet (2sk30?) that is disconnecting the distorted signal has failed. Is there any clean signal when you completely turn donw the volume and distortion?
rocket
PS I would NOT change to pedal to true bypass because it seems it relativly valuable by now, so you should get it repaired and keep it as original as possible.
You can use an external bypassbox
