resistors
Started by Stevo, June 27, 2005, 08:49:54 PM
Stevo
Can 1/8 watt resistors be used in a 9volt system.....Havent had touble yet?...or an 18 volt system...... Thanks
practice cause time does not stop...
niftydog
yes, but only if they remain under 1/8 of a watt! hell, you can use them in a 2,000V system, provided you keep them under 1/8W!
Take note of the red ones below and break out the calculator and multimeter!
Power (P, watts) = voltage x current
P = current squared x resistance
P = voltage squared / resistance
voltage = current x resistance
current = voltage / resistance
resistance = voltage / current
niftydog
Shrimp down the pants!!!
Connoisseur of Distortion
the way to test that is to put it across the lugs of a 9v battery  :wink:
(I'M KIDDING! IT'LL FRY!)   :shock:
Hal
Quote from: Connoisseur of Distortionthe way to test that is to put it across the lugs of a 9v battery  :wink:
it'll fry if...
1/8=81/r
R < 648ohms
niftydog
Hals post assumes it has the full 9VDC voltage accross the resistor. Naturally, not every resistor in a circuit has the full power supply voltage across it. Hence the need for a multimeter and some calculations.
niftydog
Hal
Quote from: niftydogHals post assumes it has the full 9VDC voltage accross the resistor. Naturally, not every resistor in a circuit has the full power supply voltage across it. Hence the need for a multimeter and some calculations.
I also assume 0 internal resistance...
and a resistor that is to spec...
