Has anyone tried using LF347N's in a Phase 90 type circuit?
Started by vanessa, July 08, 2005, 10:38:02 PM
vanessa
If so what were your results and what did you use to get it going?
:D
Transmogrifox
I looked up the datasheet on the LF347.  It's almost identical to the TL074.  It's slightly more noisey.
There is no reason it wouldn't work.  The only difference I can see it making is in the case you live somewhere you can easily get LF347's, but not TL074's as easily.
I don't think there would be an audible difference from what comes stock in a phase 90 type circuit.  If so, it would be even more subtle than the difference in a tubescreamer chip change.
trans·mog·ri·fy
