TDA1022 BBDs
Started by smallbearelec, July 15, 2005, 07:22:23 PM
smallbearelec
I have gotten in a couple of hundred of these, but I don't have a test jig for them. If you have a pedal that uses this chip and want to help out by evaluating samples, pls drop me a line at smallbearelec@ix.netcom.com
Regards
Steve D
StephenGiles
Hi Steve - how's things? I can test these for you if nobody else can over there, but of course I'm in England. Have a think about it.
Stephen
Vsat
Steve,
Building a test jig would be fairly straightforward  (if you have the time, I know you are quite busy).  Another possibility is to use an existing non-TDA1022 BBD pedal where the chip is socketed, unplug the chip, wire up a 16-pin ZIF socket to the board so the TDA1022 replaces the original chip (taking  into account the pinout and supply voltage/polarity differences...  )
Cheers, Mike
Ed Rembold
If I can help you Steve,
just drop me a line.
Thanks, Ed R
smallbearelec
Thanks for the offers. I have sent a couple to Maneco and will advise his results.
SD
