Gt-2 with electronic bypass
Started by wcampagner, July 16, 2005, 05:51:55 PM
wcampagner
Hello,
I've made a GT-2 with electronic bypass and the stompbox is working fine.
The only problem is when it is in bypass mode... i can hear a little distortion... the sound is not completely clean...
I was making some tests and i took out one of the wires of the output jack. I leave only the wire that is connected with the ground (-)... And a heard the distorced sound... So this sound is coming from the ground...
Does someone have faced it before or know something i can do to correct it?
I was reading some things about "ground loops"... maybe this is the problem that is happening with the stompbox... but i don't know how to solve it...
Thanks a lot in advance,
Wagner.
Thanks,
Wagner.
