different wiring for wah true bypass (fuzz central)
Started by fuzz_fanatic, July 18, 2005, 06:30:28 PM
fuzz_fanatic
hey,
i build the wah from fuzz central (with a red fasel reissue) and it sounds much better than the stock crybaby it had in it before. however when i switch the effect on for the first time i hear a pop noise. i guess i can fix that using a pulldown resistor in the input but i heard that there is a special wiring method so that the wah won't make that pop noise. i can't really remember where i saw it but on the DPDT switch the two outer legs were not linked directly.
if someone has or could explain me how to wire the board from fuzz central it would be appreciated (by the way GREAT site!!!!)
fuzz_fanatic
