changing inductor on gcb-95
Started by samuelk, July 27, 2005, 10:05:18 AM
samuelk
How do you replace the original Inductor in the GCB-95 with a Red or yellow Fasel.
Paul Marossy
Quote from: samuelkHow do you replace the original Inductor in the GCB-95 with a Red or yellow Fasel.
You are asking because the one currently in there has four leads and the Fasel only two? All you have to do is look at the PCB and determine what the traces are doing and then connect your new Fasel accordingly. Basically, the one in there now has two leads connected together on each side of the inductor. The Fasel will simply have one lead per side that will be connected. Take a look at this page, it may help: http://homepage.ntlworld.com/s.castledine/greenfuz/tb4.html
Just look at the PCB, don't be distracted by the other stuff (unless you are interested in doing any of it).
al3151
Use a low wattage soldering iron and solder wick and alot of care :!: The PCB traces on those Dunlop GCB boards come up really easy.
samuelk
thats exactly why i´m asking paul. thx.
i´ve modded the wah with some resistor changes already and it went well. so don´t worry al3151 =).
Paul Marossy
