Small Clone blinking LED; no signal
Started by Bernardduur, July 27, 2005, 09:57:50 AM
Bernardduur
OK, I am upgrading my Small Clone and it is working fine
for the blinking LED; when I hook ot up to the 1st pin of the IC the LED blinks but I have no wet signal. There is no difference between the on and off position. Why doesn't it work???
Could it be due to my true bypass?
Am learning something new every day here
SquareLight | MySpace account
nelson
Have you tried biasing the MN3007? Turn the 100K trim till you hear chorus....
If thats not it, check your power supply, make sure its regulated, I am havign a problem using an official EH 9v power supply (unregulated BSTARDS!) no chorus sound with power supply chorus sound with battery, I prob need to rebias it.
If that isnt it, check the wiring of yoru switch.
Then get your DMM out measure and post voltages as per the sticky.
My project site
Winner of Mar 2009 FX-X
Bernardduur
Thanks! I modded an exsisting Small Clone and did not know about the use of the trimpot. Now I have both signal and a blinking LED.
THANKS!
