70's big muff blues :-(
Started by JasonG, August 02, 2005, 09:39:51 PM
JasonG
Hey gang
  I just got a Big muff pi I thought it was a mk 2 but its a mk 3 :-(. Any way my question is, is the mk 3 supposed to sound gated? Or is it having a biasing problem? I have had a MK 2 ( I still miss it ) and it sounds more open and doesnt cut the signal.
                               Thanks !
                                      Jason
Class A booster , Dod 250 , Jfet booster, Optical Tremolo, Little Gem 2,  mosfet boost, Super fuzz , ESP stand alone spring reverb red Llama omni-drive , splitter blender ,
NEVER use gorilla glue for guitar repairs! It's Titebond , Elmers, or Superglue
Gated>? BMP is advertised as a sustain enhancer, if it's gating I'd mess with it.
 I'd measure the transistor pin voltages and work from there.
 Sticky: What to do when it doesn't work ... is a good thread to read in any case.
mrsage
What's MK2 and MK3?
I only know them based on the common terms, like "triangle muff," "ram's head," etc...
JasonG
Well there were three different modals of the BMP the first two were pretty close but the last one was alot different.  It used IC chips insted of just transistors.   I bought it on ebay and thought it was a MK2 because the knobs were 70's style but it must be an early mk3.  Google Big muff there are some good pages out there that explain it all.
bwanasonic
There are fans of the IC Big Muff, and I'm pretty certain it's not because it's gatey. I'd check that.
Kerry M
ErikMiller
As the person who makes the only currently commercially available op-amp Big Muff, I can tell you that it's NOT supposed to sound gated.
Check your power pin voltages, coupling caps....
col
I just built an op amp big muff on stripboard and it isn't gated at all. It has a similar sustain to the other types but has a darker sound, excellent for stoner rock, very similar to the sound Sleep have on 'Jerusalem'. My favourite is still the foxy lady/triangle circuit though which has been in constant use in my band since I built it last year. If anyone can pm me with their e-mail and will put it up I can send a scan of my layout but it might get into next week. I don't have a web page so I can't put pictures up here.
Last night I directly compared a clone of the current build, an op-amp version and the original circuit. They all sound very different but all sound good. The op-amp is probably the most stable version. The current build sounded good with a dynacomp in front too (on and on and on etc.) but it was a bit much for the other two versions.
Col
JasonG
Sir H C
The op-amp one has a great sound.  If it is gated, then most likely there is a DC biasing problem.  I would guess that the inputs to the op-amp are pulling to the rail (or ground).
I have an old op-amp BM and have compared it to Erik's, and his is identical in a smaller box.
jimbob
QuoteAs the person who makes the only currently commercially available op-amp Big Muff, I can tell you that it's NOT supposed to sound gated.
I chked out your site= nice..
Anyways- I have been finishing up my take on the 3 different BMP's at the Tonpad site.  All sound Very good.. However, I havnt came across a layout for a op-amp muff. Are there any out there?
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
soggybag
I've never seen a schematic for an op-amp Big Muff? Can anyone point me to one. I'm very curious what's going on with this? I have seen plenty of transitor versions that are all really the same. I have also seen the Swollen Pickle Schematic, which uses a quad transistor array on 14 pin dip.
AL
