Arion SAD-3 symptoms. Any ideas?
Started by dpresley58, August 24, 2005, 12:28:16 PM
dpresley58
My cousin brought a problem to me with the Arion SAD-3. After playing through it for awhile, the sound gets fuzzy and the volume drops. From what I see, (can't find a schematic) it uses MN3205 and MN3102 chips.
Any thoughts on things to look for or probable culprits with this?
Little time to do it right. Always time to do it over.
Paul Marossy
Battery. Those things will eat batteries in a short while. I would be afraid to use it for a four gig on just a brand new battery!
dpresley58
Thanks, but the battery isn't an issue. Its running off of a power supply.
Paul Marossy
Oh, I see. Hmm... no ideas on that one at this time. Here  is a schematic of the SAD-1. The SAD-3 is probably pretty close to this, AFAIK.
dpresley58
'Preciate it, Paul. I guess it's time to break out the old audio probe and get to pokin'...  :?
With any luck, someone else has had this problem, or could offer some theoreticals on it.
ExpAnonColin
Quote from: Paul MarossyOh, I see. Hmm... no ideas on that one at this time. Here  is a schematic of the SAD-1. The SAD-3 is probably pretty close to this, AFAIK.
Meh, not really.  But I thought this thing didn't run on MN3205s?  I thought it ran on BL3208s or something.
Anyways, sounds like a bad cap if you are using a power supply.  Perhaps in the power supply or biasing areas.
-Colin
Paul Marossy
Quote from: ExpAnonColin
-Colin
Some SAD-3 pedals use an MN3208 according to this thread:
http://www.diystompboxes.com/sboxforum/viewtopic.php?t=23339&highlight=sad1+sad3
There are probably 2-3 versions of the SAD-3 as there was the SAD-1. I was under the impression that the two circuits aren't that different from eachother. Anyway, the power filter cap may be faulty as you suggest.  8)
EDIT: Also check out this http://www.diystompboxes.com/sboxforum/viewtopic.php?t=20289&highlight=sad1+sad3
Fret Wire
SAD-3 has a MN3208, 50-200ms delay. SAD-1 has a MN3205, and is 50-300ms delay. Maybe later, I'll take a pic of an SAD-3 board.
Fret Wire
(Keyser Soze)
Paul Marossy
Quote from: Fret WireSAD-3 has a MN3208, 50-200ms delay. SAD-1 has a MN3205, and is 50-300ms delay. Maybe later, I'll take a pic of an SAD-3 board.
Any idea on how close the two schematics would be?
