A bit OT: Horizontal tubes
Started by ninoman123, August 27, 2005, 11:28:51 PM
ninoman123
Im building a new amp and I might have to make some of the tubes horizontal. Does this cause any problems with noise? Does it only do it to certain types of tubes? (pentodes vs triodes or rectifiers)
FeDomic
I built a Soldano X88R clone with 6 12AX7 tubes mounted horizontally, and I have had not noted any problems with that.
Some Mesa's have triodes and pentodes mounted horizontally too.
ninoman123
Alright cool. Anyone else have any advice in this situation? Im trying to get any and all experiences with this that I can.
JimRayden
*Don't place the preamp tubes right next to the PT.
*Don't run the mains cable back and forth all over the chassis internals.
*Don't hang the tubes upside down without retainers.
*A light bulb is NOT an electronic tube.
*Umm... Don't attach the loudspeaker right on the chassis.
That's about it.
Jimbo
Connoisseur of Distortion
Quote from: JimRayden
Jimbo
care to explain?  :)
JimRayden
It's a monode, so it won't have any use as a gain stage nor a rectifier. :)
Jimbo
Tubes have these great datasheets that tell you what position the tube can be mounted in.
Some tubes may only be mounted vertically, and others horizontally only in certain rotations. The datasheets tell you this.
Due to the ***extreme*** compression of tube types down to essentially one preamp tube (12AX7) and a few output tubes, the ones we have left are largely the non-position-sensitive ones.
FeDomic
Quote from: R.G.Due to the ***extreme*** compression of tube types down to essentially one preamp tube (12AX7) and a few output tubes, the ones we have left are largely the non-position-sensitive ones.
Darwin predicted it for living beings, curious it happened for tubes too.
putrefusion
Gee, I really miss those 6414s...  :lol:
I'm Elmore James, bitch!
Regan
You could also base the layout on a tweed style tube amp layout, just sideways :)
Regan
ninoman123
Yeah I would except Im ordering a premade cabinet for the chasis. The chasis is top mounted. This is what it will look like
And since my build has two more tubes, I was either going to smash them all together or put some on the big flat part of the chasis, but when the chasis would be mounted in the amp that would make the tubes horizontal.
Regan
That should  be cool, I have seen amps with tubes mounted on both areas, I think even vox had amps like that.
Regan
