LPB2 possible mods question
Started by Xavier, September 05, 2005, 03:39:53 AM
Xavier
I've been using this boost for a couple of months and so far I'm happy with it. I'd like to perform some mods on it though.
- What can I do to reduce the highs somewhat? it's a little too bright for my tastes. Any trim pot to add?
- I used a 2N5088 transistor. According to the datasheets, the 2N5089 has 25-30% more gain. Will it be noticeable if I swap the 88 for a 89?
Thanks in advance !!
MartyMart
Hi, you could just use a roll off cap, from signal to ground just before the
output, try a 1n ( 0.001uf )  to 10n ( 0.01uf ) or something inbetween and
see how you like it.
If possible, socket this connection so you can "plug and play" with the values.
For me, most times a 2n2 ( 0.0022uf ) cap is a good roll off point, but its
different for each persons circuit/ gtr/amp setup
Yes you'll get a gain lift when using a 5089
Marty.
nelson
Could tack on a stupidly wonderful tone control....
http://hammer.ampage.org
My project site
Winner of Mar 2009 FX-X
Xavier
Thanks for the answers. I'll change the transistor and try different cap values.
Great booster !!
For adjustable highs...Signal path> cap> pot> Ground...
see AMZ labs notebook and FAQ>simple mods and tips.
