installing a 3pdt into a boss pedal
Started by John Egerton, September 06, 2005, 01:12:54 PM
John Egerton
hey guys...
I've done this with 3 of my most prized boss pedals, only to realise that the damn things pop when bypassed...
I've tried the usual of using a pulldown resistor on each end but to no avail... has anyone had any similar encounters when doing this?
John
Save a cow... Eat a Vegetarian.........
bioroids
How much popping are we talking about?
If the switch is good and connected right, it should not pop, at least not much. No matter if its a Boss pedal.
Are you sure you connected the pulldown resistors right? In that case, maybe changing the input and output caps for low-leakage ones may help (if they are bad quality electros they would cause some popping).
Otherwise, i'm clueless!
Luck
Miguel
Eramos tan pobres!
John Egerton
yeah, it sound like a very promininet electircal popping sound, not your average stompswitch click that I would have expected...
I'll try changing the caps tonight to see...
