diodeless tubdescreamer . . ?
Started by vseriesamps, September 18, 2005, 04:36:28 PM
vseriesamps
Hey team
I searched the FAQs and the archives but I couldn't find anything that quite touched on this.
I was wondering whether it would be possible to pull the diodes fom a Tubescreamer in order to make it almost clip-less . . . or would this wreak havoc bc the diodes wouldn't be there to perform some signal limiting?
I use my TS primarily for color, and is curious what the best way to clean it up is. Back to back LEDs?
Thanks in advance for all your help
-Kyle![/i]
uh oh
Basstyra
Remove the diodes, remove the resistor in serie with the gain pot (allowing less gain).
The best french bass-related forum : http://forum.onlybass.com
A french DIY forum : http://www.techniguitare.com/forum
My work (stille only in french, sorry ! ) : http://perso.wanadoo.fr/jumping-jack/atelier/atelier.html
bioroids
Using leds instead of both diodes will certainly clean it up. But wouldnt be totally clean anyway. I think the clipping contributes something to the color anyway, as they generate harmonics.
Luck!
Miguel
Eramos tan pobres!
Seljer
I'm not sure but when I take the diodes of my proco rat clone I just get a huge volume boost without the clipping....so yes, I think taking the diodes out will do what you're thinking about.
I think there was a page somewhere (but the main page is down) about using 2 diodes in series in each direction for less clipping and more gain too.
I'm pretty sure someone will come soon and say what you can exactly do..
vseriesamps
I didn't look hard enough. Here's basically my same post.
http://www.diystompboxes.com/sboxforum/viewtopic.php?t=36409
Anybody got more info? Thanks always.
k
uh oh
aron
Yes, you can pull the diodes and even run it off of 18V.
