wiring a stereo input jack without battery
Started by powerplayj, September 12, 2005, 11:51:25 AM
powerplayj
I built a BSIAB2 but opted not to use a battery lead even though I used a stereo input jack.  Does the ring need to be be connected to anything in absence of the neg battery lead (perhaps grounded to the sleeve)?
Thanks,
Jason
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
Supplying power directly to the circuit...you will have no use [afaiksee] for the ring connection of the St input jack.
