so i'm cloning my coron distortion 10....
Started by showofhands, December 10, 2005, 11:29:44 PM
showofhands
So I'm cloning my Coron Distortion 10 with quite limited building experience (2 BYOC kits that turned out great), and I have a pretty rudimentary question regarding the schematic available on this site.
It looks simple enough, but I don't know where I'm supposed to wire in the knobs or the switch  :icon_redface:.
If you take a look, there are three arrows in the schematic:  one on the far right pointing to the 50k resistor, one to the upper left pointing to the 500k, and one from the output jack to a contact point.  Is this what I'm looking for?  If so, I'm assuming the one at the jack is the switch and the other two are the volume and gain?
If I can just get this sorted out I'll be all set and I'll have a backup of my precious old Coron.
Thanks for any and all responses.
tungngruv
If this is the schem
http://www.diystompboxes.com/pedals/dist10.gif
here are the connections. (The 50K and 500KR are pots.)
.01uf to input of switch
lug two (middle arrow) of 50K to output of switch
2 germ. diodes/4n7 to lugs one and three (look at the schem) respectively
47n/3K3 to lug two & three of 500K
lug one of 500K to ground
Wire up the swwitch like this:
http://www.diystompboxes.com/pedals/DPDT.gif
