Need help with fuzzface
Started by warioblast, October 23, 2005, 02:03:28 PM
warioblast
Hi,
I built a Si NPN Negative Ground and I have a little problem.
when the fuzz pot gets to full setting, the sound becomes gated which seems a redondant issue with Ge PNP Negative Ground  :icon_sad:
I replaced the ouput cap; 0.01uF instead of 0.1 uF; I sold all the ground spots to the circuit, I added a 220uF cap from +9V to ground but the problem is still here.
how can I fix it ? do you guys have any suggestion on a mod to be done ?
Cheers,
Fabrice
Joe
Unless it's a wiring mistake, it probably needs to be biased. Try this calculator:
http://www.analogalchemy.diystompboxes.com/emh/emh.html
(custom fuzz-face section)
warioblast
THX, I'll give it a try tomorrow.
My R1 is 33k, the calculator suggests me 7K.
Great little site by the way
  replace Q2 collector resistor with a 10k-20k pot, this allows you to adjust bias to suit a wide range of transistors, 'instead' of finding transistors to match the bias setup.
  I always had good results with a 33k - 47k [even 100k trimpot turned all the way up] resistor for Q1 collector.
jmusser
On Laurier's Handy Dandy Little Circuits  http://members.shaw.ca/roma/fuzz.html  He has a Fuzz Face layout there, that uses about all trim pots. I believer that's the version I'm going to try before long. It looks like it can handle about anything you can throw at it!
Homer: "Mr. Burns, you're the richest man I know"            Mr. Burns: Yes Homer It's true... but I'd give it all up today, for a little more".
  I've had my handy dandy ''mostly trimpots and sockets' FF testboard down in the lab for sometime now.
  Anytime I want to mess with some different transistor types, and get some usable bias or sound, I can revoice the circuit.
  I haven't whipped it into the test jig for sometime now because I used it to 'find' most of the FF's that I have re-built [with fewer sockets and trimpots] around what I found with the FF Testboard, and subsequently boxxed.
warioblast
I forgot to tell you I had a mid pot, it adds confusion to the debugging. Pete, I have already a trimpot  :icon_wink:
I socketed the 33k resistor, I tried 2.2, 10, 33, 47, 68 et 100k. When increasing the value, the gated sound slightly goes away but it adds a touch of octave-up. So I put back the 33k.
I made a short clip with my digital camera, it doesn't really show my problem but well it's already here...http://fabrice.detang.club.fr/temp/ff.avi
Tomorrow I'll try swapping out the 500k pot for a 100k.
to be continued...
