Help with wiring Jazz Bass
Started by jrc4558, October 25, 2005, 02:13:23 PM
jrc4558
Hi everybody!
I want to rewire my bass to have master volume, pan control from neck to bridge and a master tone control. One thing I noticed is that with whichever wiring I used so far for the pan control, i dont get the maximum output from both pickups in the middle position. Been thinking of it for a week now, no ideas. Can anyone recommend a potentiometer and wiring for that? Or maybe a cirquit(i don't mind active there and do have room for a battery)? Thanks!
Bernardduur
Check out this. I build it and I love it.
Ok, now it is in a pedal, but it used to be on my bass....... I just hated the 9V battery
Am learning something new every day here
SquareLight | MySpace account
Joe Viau
#3
While you're at it, you may want to consider series / parallel switching as well...
The black rectangle on the tone pot is a capacitor.
There's a lot of info over at talkbass.com about wiring and such, as well as problems and solutions that some people have had. Here's the thread where this came from:
http://www.talkbass.com/forum/showthread.php?t=141764&highlight=volume+blend+tone+series+parallel
And another...
http://www.talkbass.com/forum/showthread.php?t=36642&highlight=pan+wiring+diagram
The Stew-Mac link on the second is broken, but if you go to stewmac.com and click on Free Information you should find it. ** EDIT ** "it" being a blend pot schematic.
HTH,
Joe
jrc4558
#4
Whoa! thanks! However, any other place to buy this blend pot from! ;) Or maybe I could just use a regular balance control? Maybe linear taper will do? Any experience with those?
melvin
I have found old stereos to be a great source of uncommon pots.  Mostly I come across broken portable tape/radio players, and they almost always have a balance control for the left & right speakers with a centre detent.
Joe Viau
Stewart MacDonald here in the US has them:
http://www.stewmac.com/shop/Electronics,_pickups/Potentiometers_and_push-pull_pots/4/Control_Pots.html
Item 4138, a 500K dual blend pot will set you back $5.34 USD.  I've dealt with StewMac several times and always have had good luck with them--they've been around a long time.
Regards,
Joe
jrc4558
Ok! Ordered 500k pan pots from Stew Mac. Thank you gentlemen!
SonicVI
Definitely do the series/parallel switch. It was the best mod I've ever done. Well, it's the only mod I've ever done to my Jazz Bass, but I'm glad I did.  I use the series mode more than the standard parallel now. It's like playing a Jazz Bass that sounds almost like a Precision Bass, much fatter and rounder. And then if I want the normal Jazz Bass sound it's still there.
Bernardduur
I totally agree. A jazz bass in series is the best sound!
jrc4558
I'm using Di-marzio Ultra Jazz  pickups. They're pretty high output already. :) And noiseless.
Btw, which pickups for jazz bass do you guys like? sorry, offtopic...
Bernardduur
I am still using my Farida Jazz Bass stock pickups. The bass was the cheapest in the store but the pickups really can sing (and are noiseless)
SonicVI
I have a Japanese '75 reissue that came with standard USA Vintage Jazz pickups. They sound good enough for me with my SVT3Pro and 4x10.  I may try something new someday just for fun.
here's a pic of my lovely bass btw, the tone control is a push/pull for series/parallel:
http://homepage.mac.com/sonicvi/bc2.jpg
Joe Viau
I currently have an old set of DiMarzios on a Jazz Bass copy, but I like Seymour Duncan and Bartolinis just as well.
My Dean Jeff Berlin Signature has Barts and I do like the "transparency" of the pickups.  Many feel that it's better to let your outboard electronics color the sound rather than have the pickup itself define the sound.  Duncans have a tone that I like, and the EMGs seem a little harsh to me.  But if you like the EMG sound, enjoy, and more power to you.  :icon_biggrin:
Tubebass
I'd like to chime in on the series/parallel thing. I liked series so well that I just wired my bass permanently in series.
More dynamics????? I'm playing as loud as I can!
