AMZ Boost Diode prob ?
Started by criss, November 05, 2005, 07:44:49 AM
criss
Sorry to sound stupid
http://aronnelson.com/gallery/album18/AMZ_MOSFET_BOOST_VERO
But i build the amz boost and for the diode i used a plain 9.1volt zener . But looking back i see its a diode but a rectifier power diode i should have used .
The boost is working but theres not much boost there ( amp is louder without the boost on )  Im guessing its the plain diode stopping the boost ?
Can i use a 1n4007 in place of the 1n4001 i should have used . Or maybe a 1n4148 small siginal diode ?
Thanx for your input
dosmun
QuoteCan i use a 1n4007 in place of the 1n4001
Yes
criss
Thanx
So im guessing my diode muck up is whats causeing very little boost ?
amz-fx
Quote from: criss on November 05, 2005, 07:44:49 AM
This is one of the reasons that I really hate it when someone redraws one of my designs...  the diode is NOT a 1N4001 as shown on that drawing but a 9.1v zener as shown on the original at:
http://www.muzique.com/schem/mosfet.htm
Always use the original as reference...
So...  that cannot be your problem with the circuit.   Double-check your orientation of the transistor.  If that is not it, measure the DC  voltages at the legs of the mosfet and I will see if I can figure it out.
regards, Jack
criss
Thanx Jack
My stupid mistake was the transistor was in backwards . I switched out the 9.1volt diode for the one mentioned in the schmatic  :  ( but changed it back to the 9.1volt diode . And all is working
Thanx again
