help with Ross Comp please (Tonepad layout)
Started by powerplayj, November 11, 2005, 11:33:29 PM
powerplayj
Ross Comp using Tonepad layout: http://www.tonepad.com/getFileInfo.asp?id=9
2N5088 trannies, 9V well-regulated power supply (9.1V)
Symptoms:  No sound at all except increased hum/gaim when turning up volume pot.  Turning sustain pot has not affect sound (hum) ???
IC
2. 1.9V
3. 1.9V
4. 0V
5. 0.6V
6. 3.2V
7. 9.1V
Q1. 8.1, 0.1, 0.2
Q2. 6.4, 3.2, 2.6
Q3. 7.3, 0.0, 0.0
Q4. 7.3, 0.0, 0.0
Q5. 9.1, 7.6, 6.8
Ideal values from Fuzz Central are
IC
2. 4.9V
3. 4.9V
4. 0V
5. 0.6V
6. 2.8V
7. 9.5V
Q1. 8.0, 2.1, 1.7
Q2. 7.3, 2.9, 2.3
Q3. 9.5, 0.0, 0.0
Q4. 9.5, 0.0, 0.0
Q5. 9.5, 9.3, 9.0
Any help to narrow down the troublesome component would be much appreciated.  I'll work on the audio probe in the meantime.  Thanks,
Jason
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
nelson
Just looks to me as if you VB is too low, check the voltage divider resistor values.
My project site
Winner of Mar 2009 FX-X
Fp-www.Tonepad.com
Q1 is misbiased, check the resistors connecting to it.
Fp
www.tonepad.com : Effect PCB Layout artwork classics and originals : www.tonepad.com
powerplayj
....touched up a few caps and resistors and now I am in business.  Wow!  this thing is nice and smooth and doesn't have the brittle tone that I noticed with the Dynacomp.
next build(s): ???
Fp-www.Tonepad.com
