Amp Switch
Started by chago04, December 01, 2005, 04:35:10 PM
chago04
I have one Marshall 4x12 cabinet that I use for my amps, and I would like to rig it up so that I dont have to pull out the cables every single time I want to use a different amp.  I know an AB box wont work, so does anyone have a schematic of something that will?
JimRayden
I remember a product that would allow switching between two heads into one cab.
If you have tube amps, you might hurt them when disconnecting the cab on the run, it needs another load behind it as soon as you disconnect the speakers.
I'm sure there are lots of more problems with it... I think it would be easier to wire two speakers up for one amp and two for the other. Then you can use a simple AB box.
Jimbo
Paul Marossy
How many amps are we talkin' about, and are the all expecting the same speaker load?
Khas Evets
geertjacobs
http://www.aikenamps.com/HeadSwitch.pdf
A friend of mine built one and it's working great.
