EA TREM - switching caps to adjust speed range
Started by aaronkessman, June 21, 2004, 11:09:35 AM
roknjohn
I replaced the 1uf caps with .47uf and then messed with the resistors to get the range of control I wanted. Seems when I changed to .47uf, the oscillation would stop at one end of the pot travel until I adjusted the resistors. I also used an internal trimmer in place of the level pot, and adjusted it for unity.
Also used a dual color LED so I could monitor the rate when it is in bypass mode.
Tried several tremolos before this one, but this one was exactly what I was looking for. Sounds great.
Here's a pic of my finished box.
http://i25.photobucket.com/albums/c57/roknjohn/bd4fdac8.jpg
