Condor cab sim; how to use it?
Started by Bernardduur, December 14, 2005, 06:26:34 PM
Bernardduur
OK, I have a little question:
how do you use a cab sim (as in the ROG's Condor Cab sim)? Do you add it to the end of your effects and plug it into a mixer or can you "beefen up" a direct signal (from a direct out on an amp)? I read a lot of posts but I was not sure how they used theirs.....
Am learning something new every day here
SquareLight | MySpace account
stm
Quote from: Bernardduur on December 14, 2005, 06:26:34 PM
You can use it both ways. See what you like best, and if it suits your tastes.
Bernardduur
#2
OK, thanks!
Is the FET needed when using a direct signal?? It tends to distort
stm
Quote from: Bernardduur on December 15, 2005, 07:15:55 AM
The idea of the FET was to simulate the saturation characteristic of the speaker and add up some gain to compensate for the insertion loss of the bridged-tee notch filter. FETs don't saturate as gently as the speaker, so in this case you can try one of the following alternatives:
1) Use minimum GAIN (if distortion/coloration is acceptable)
2) Disconnect the FET and apply a line input directly at the first 47n capacitor. Overall level will be less than unity, though, which you can compensate by making U1:A to amplify adding feedback resistors between OUT and -IN and -IN and VREF, if really needed.
Regards.
Bernardduur
Ah thanks.
I tried the second options as no distortion is needed in some parts, and it works like a charm. I use the mixing board and the guitar amp to compensate for the loss.
