GGG Blues Breaker
Started by swal, December 22, 2005, 12:16:57 PM
swal
What is going on with the wiring on the orignal version of the bluesbreaker, is there anyway to make it a true bypass with a dpdt and no led. I tryed to wire it like all the other pedals I do but of course it doesnt work, or am i stuck with tone sucking with a 3pdt. http://www.generalguitargadgets.com/pdf/ggg_bluesbreaker_orig_wiring.pdf
S J Waldner
jsleep
Whoops, I'll repost the true bypass wiring diagram.  I think it got accidently dropped on an update.  To do it, you totaly ignore the bypass output from the board and use the output wire on the far right side as you would wire a pedal normally.
JD
For great Stompbox projects visit http://www.generalguitargadgets.com
