Ogange Sqeezer Led problem.
Started by jpm83, December 23, 2005, 05:44:41 PM
jpm83
My problem is that, when effect is turned on and led is connected there is no sound coming thru. As led I´m using DPDT switch and led trick but I used in the place of 330k resistor 390k resistor and in the place of 2N3904 transistor BC547 transistor. All the components are pointing in right direction and are in right places. There is also a 100k resistor connected to the ground from the switch. And wiring of switch is OK too. And when I disconnect the led board from circuit the effect just works OK. I´m using this circuit.
http://www.diystompboxes.com/analogalchemy/pedals/ledtrick.html
Sorry about my english and thaks for answering.
jpm83
jpm83
Is there something wrong in My question? Can you understand it?
Merry Chrismas for all of you.
Janne
jpm83
Could it be that led circuit sucks the current from main circuit?
Joecool85
I think its that you would have to play with the values alot to get that tranny to do it.  That setup was strickly for 2n3904s.
Life is what you make it.
https://www.ssguitar.com
no one ever
i was about to say that, joe.
you're absollluuuutely certain its the led board and not the actual circuit?
(chk chk chk)
jpm83
Thanks for answering.
I just have to get that correct tranny or try that millenium bypass again when I get those BS170 trannys. (The place where I ordered them was on leave). And maybe if I check the main circuit once again would be good too.
