Wah out of a Volume pedal project
Started by koz, December 22, 2005, 09:11:24 AM
koz
Hi everyone!
First of all, this is my first time trying to built something from the ground up
and i hope the somebody can help me on this.
I don't know if call this a Mod or a build,
because i got this Vox Volume Pedal and i was thinking to make a wha pedal out of it,
Here's The Schematic i will try to follow
http://www.geofex.com/Article_Folders/wahpedl/wahped.htm
or if somebody can recommend to me another one simpler it will be helpful
This is what i got so far:
Resistors:
                1k
               10k
               15k
               22k
               33k
               82k
              100k
              470k (x3)
Capacitor:
              0.01uf (electrolytic capacitor)
              0.01
              0.22 (x2)
Transistor:
              NPN (x2)
Inductor:
             500mh
? This one i don't know what is it.
any other thing the i miss, just tell me.
remmelt
The symbol is a capacitor. This one is a 4.7 micro-Farad. The u is really a micro which looks the same but has a longer second leg. Regular capacitors have two straight lines, this one has a straight one and a half circle: it has a plus and a minus side. Usually this means that it's an electrolytic capacitor, the kind that looks like a can with two legs sticking out one side (there are caps like that with a leg on each side too.) Take care which way the minus side goes! The plus always goes where the voltage is highest.
There are a lot of wha's on the page you linked to, which one will you build? Check if your pot has the right value: the one that moves when the pedal moves.
Paul Marossy
Well, you have the hard part of building a wah pedal - the shell! The rest is easy in comparison...  :icon_wink:
You can get a red or yellow Fasel inductor from one of several sources. The transistors can be one of several NPN transistors. I personally like BC109s, but MPSA18s work well, too. (as well as many others)  :icon_cool:
