a new fuzz for the new year
Started by Joe, January 01, 2006, 02:59:43 PM
Joe
Marcos - Munky
Very simple and interesting. What about to use a trimpot instead the 100K resistor?
Joecool85
:-( thats basically the gain stage of my pedal I'm designing...except I'm use a 10k resistor and two MPSA13s.
Life is what you make it.
https://www.ssguitar.com
Paul Marossy
Looks very interesting. How does the base of the second transistor connect to the first one? Are they both connected? I haven't seen anything like that on a schematic before...  :icon_confused:
Joecool85
On mine the input signal goes to the base of both trannies.  Looks like JD's is the same.
Joe
This one uses an NPN and PNP in parallel, not both NPN. The emitters, bases, and collectors are all attached. Normally a PNP transistor would be inverted in a negative-ground circuit but not in this case.
Joecool85
Ah, so its a little different than mine...since mine just uses two NPNs in parallel like that.
chokeyou
reminds me of a harmonic percolator with the stages swapped.
mac
I've seen something similar to this circuit some years ago. See the article below. The difference is that the pnp is inverted.
I have tested it and it sounds nice and smooth, much better than most pedals I've heard, but the bias may be hard to set.
I also built my own circuit very similar to joe's schem. If anyone is interested send me an email to mailto:lic_mt@fibertel.com.ar and i'll send you the schematics.
Date: 04 Jul 95 23:04:50
Newsgroups: rec.music.makers.guitar
Subject: New Overdrive Circuit
Organization: MtlNet (MBA.org) MBA [514-465-8524] Brossard, QC
Hi,
I've noted that talk on this echo always comes back to the subject of
overdrive distortion.  Whether generated by a vacuum tube amplifier or
a transistor amplifier there seems to be undeniable differences to me
as well.
Lately, I was tinkering with an unusual transistor circuit
configuration I had come upon a few years ago and made a few
modifications to the circuit that turned it into one beautiful
screaming "tube-like" overdrive but without the wall of noise these
things usually make.  When pushed it even makes that distintive
"zoo-zoo" sound...!!!
The original circuit was simply a complementary matched pair of
transistors connected so that all the terminals overlapped.  i.e. both
bases tied together, emitter of the PNP connected to the collector of
the NPN, and the collector of the PNP connected to the emitter of the
NPN.  Thus:
                          ___________o
               2N3906    |      |
                    b  |< e   |/ c
                   o---|------|    2N3904
                       |\ c   |> e
                         |______|____o
This transistor pair is then biased by 2 equal value resistors in each
of the compound legs, one to the positive supply and the other to
ground common.  The signal is coupled to the base pair leg and the
output is picked off either of the other 2 legs.
The result is that the above circuit exhibits the behaviour of a
multiplier over a range of signal values.  It basically performs a
sin function: in other words a frequency doubler.
This doesn't have a very good distortion sound though because it is
rather "burpy and buzzy".  However, lately I was toying with the
circuit when I offhandedly decided to try doing something to it just
to see what would result.
After adding a large cap from the NPN's emitter to ground the thing
went wild on me...  WANGO ZE TANGO!  SUPREMO DISTORTION!  I then
proceeded to refine the circuit a little more and got a better
understanding of what it was doing.
The final schematic follows but first a couple of notes on the
circuit.  The "bias balance" trimmer should be adjusted for a
symetrical clipping threshold of the output signal as viewed on a
scope.  Short of this it can be easily set by "ear" for the most
sensitivity somewhere around mid-turn.
The input should be driven by a lo-z stage if your electric guitar
doesn't have a built-in pre-amp.  You can alter the emitter capacitor
value in a range from 0.1uF to 1uF in order to obtain various basement
characteristics but I found the indicated value is a good compromise.
The input capacitor should not vary much either though because if it
is made too large the circuit goes balistic and cuts out on the tutti.
"Tube-sound" Distortion Overdrive Circuit:
              _____________________________o + 9volt battery
              < bias balance         <
        20K   < <--.  set            < 10K
      trimmer <    |                 <
             _|_   < 220K            |    0.1uF
             ///   <      ___________o----||----o output
                   <     |      |   c
          0.0047uF | b |< e   |/ c 2N3904
input   o----||---o---|------|
                       |\ c   |> e
                         |______|____o-----
                   2N3906            |     |
                                     <    ---  0.22uF
                                 10K <    ---
NB:  2N3906's gain matched           <     |
      with 2N3904's                  |------
                                    _|_
                                    /// gnd common
The operation of the circuit more closely resembles a vacuum tube than
a diode clipper does because of the strong square law characteristic.
This is due to the negative feedback around both base-emitter pairs.
This feedback accentuates the junction non-linear behaviour manyfold.
Thus each transitor drives the other even harder so that the transfer
curve ends up more logarithmic than is typical of a single transistor.
In other words: the clipping is gradual and not abrupt like it is in
the case of a silicon diode.  Typically a lot more 2nd harmonic is
produced as well.  As a bonus the waveform folds over on itself when
the circuit is overdriven!
Now in the interest of the common good I donate this design to the
public domain for personal use but retain copyright and reserve all
rights for any commercial purpose.  In other words build one for you
and your friend but if you have it massed produced for profit I only
ask a fair share.
Please, do try the circuit and leave any comments in private at my
e-mail address:  arsenio.novo@mba.org
Arsenio
