Small Stone true bypass with LED??
Started by Jayco, January 05, 2006, 05:02:13 PM
Jayco
Hey all..
I'm working up the mods for my Series J Small Stone to make it sound a little more like a Univibe... easy enough.
However, while I've got the case cracked open (and will be moving it to a 1590BB case hopefully), I'd like to add true bypass AND and LED to it.
I've read a few places that say this can't be done because of how the circuit needs to stay charged up etc, but I don't know enough about it to make an educated guess.
Has anyone done this?
Thanks,
Jim
no one ever
wire a 3pdt just like a dpdt (signal routing) + an spst (for grounding led)
(chk chk chk)
Jayco
Yes, but I've read that something about that doesn't work with the Small Stone... its not the LED portion, its the true bypass portion.
Aparently, however its normal bypass works, there is still signal charging the LFO's etc... and without that (using true bypass) the pedal has a delay before it make sound when activated.
Jim
no one ever
Quote from: Jayco on January 06, 2006, 01:06:25 AM
Jim
:icon_eek: didn't know the small stone was a special case.. nevermind  ;D
(chk chk chk)
