20KC Pot??
Started by finkfloyd, January 13, 2006, 09:23:53 AM
finkfloyd
Hi, I am about to replace the feedback pot on my old vestax digital delay pedal as it is really scratchy, question is what is the "C" marking?, is this an older marking for log or linear? I would think it should be linear. I've searched and cant find any info.
I only have 100K pots as the smallest so I will use the resistor trick with 2 X 12K resistors bringing it down to to a close 21K
Also my pots are are like 1 in the diagram below
                                                            MMMMMM
                                                            M    M
                                                            M    M
                                                            M    M
                    MMMMMM                                  M    M
                    M    M                                  M    M
                    M    M                                  M    M
                    M    M                                  M    M
                    M    M                                  M    M
                    M    M                                 MMMMMMMM
                    M    M                                 M      M
                    M    M                                 M      M
                    M    M                                 M      M
                    M    M                        MMMMMMMMMMMMMMMMMMMMMMMMMM
                   MMMMMMMM                        M                       MM
                   M      M                       MM                       MM
                   M      M                       MM                       MM
     MMMMMMMMMMMMMMMMMMMMMMMMMMMMMM            MMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
     MMMMMMM                       MM          MM
     MM   MM                       MM          MM
     MM   MM                       MM          MM
      M    M                       MM
        POT A _ POT B
Eirik
I think a C-taper pot usually is a reverse log. Like the one used in tubescreamers.
Eirik
finkfloyd
Hi, replaced it with a 100K linear, with the 2 resistor trick and it seems to work fine, no more horrible loud scratchy sounds when adjusting.
I cant hear any audible difference with the replacement
