Help Identifying Components on old Schem.
Started by nelson, June 18, 2005, 04:48:46 PM
nelson
Quote from: StephenGileshttp://img.photobucket.com/albums/v517/uncle_boko/EHpolyphase.jpg
To the rescue!!!!!!
Stephen
The schem is V similar to the Polyphase, but it isnt the same. The PS is different and pin 6 of last 4558 in top section goes to a B voltage.
My project site
Winner of Mar 2009 FX-X
StephenGiles
I could have sworn a Deluxe Phaser circuit was posted here earlier with Polyphase printed on the bottom!!!
All my deluxe Phaser circuits from different sources are dated 20 July 1978 and none have pin 6 of last 4558 going to a B voltage - sounds like somebody has messed about with the circuit somewhere along the line.
Stephen
puretube
StephenGiles
Here is the data sheet for the CLM 8200:
http://img.photobucket.com/albums/v517/uncle_boko/CLM8200.gif
Perhaps someone can let us know which VTL5C? will substitute for this. Is this big enough?
I wonder what other gems are lurking in my cupboard!!!
Stephen
nelson
Again Stephen, your a god send!!
5K light 10M dark.......
The rest I can just about make out....
My project site
StephenGiles
Nelson, I'll email you a larger version of the 8200 data sheet later - have to walk the dog, then shopping, then a concert by some ex Sahara Desert terrorists - need new batteries for the minidisc!!!
Stephen
nelson
Quote from: puretube
Quote from: puretubehttp://diystompboxes.com/sboxforum/viewtopic.php?t=7370&highlight=polyphase
:oops:
erratum: http://diystompboxes.com/sboxforum/viewtopic.php?t=3367&highlight=polyphase
In that article Howard davis talks about the polyphase as if it were the polychorus/echoflanger. For the EH man he makes some ridiculous mistakes.....
"I designed the current Polyphase reissue, but NOT the original, which also went by the names Polyflanger and Echoflanger (all the same product). I believe this is one of the most flexible multi-effect pedals around; you must play through it for quite awhile in all of its modes, trying various control settings, to apprecaite all that can be done with it."
There is no polyphase reissue!!!???
anyway, thanks Stephen.
No useful info can be gleamed from that thread relating to the polyphase Puretube.
Why did you link to it?
My project site
puretube
he probably meant "PolyCHORUS"-re-issue...
why post link?
combine the hint in the last post on this page:
http://diystompboxes.com/sboxforum/viewtopic.php?t=34110&postdays=0&postorder=asc&start=0
with the info from that old thread...
:wink:
nelson
:wink:
I am gonna send him an email....
My project site
puretube
...on 2nd thought, I dunno how he reacts if he sees his artwork published
:shock:
nelson
*his* artwork has not been published.......... :)  He does sell EH Schematics.......
hmmmmm
I sent him an email about the echoflanger shortly before reading your posts so I will wait a while before asking him about the Clone Theory, see how helpful he is. The only mod I want to do to the clone theory is a wet stereo out, which shouldnt be too hard, given that I have the small clone mod from tonepad to work from. A blinking LED and maybe a rotary switch to play with the feedback resistors.   8)
I am V curious to find out what "vibraflange" sounds like.  :)
My project site
nelson
Ok I have found a Vactrol with specs V close to the CLM8200/2, I would like some other opinions though, incase i have overlooked something. It is the VTL5C3/2 Datasheet can be found here
http://old555.com/LPE/PDF/Vactec/VTL5C2X2-3X2.PDF
Now, is this a good substitute for the  CLM8200/2?
I plan on leaving the thermistor out of the circuit, what value resistor should I replace it with?
I also cant identify the single opamp to the right of the 4013 flip flop, any ideas? pin7 to V+....
My project site
A.S.P.
Analogue Signal Processing
