how to connect a 3-pole 4-position rotary switch
Started by BoksteR, February 05, 2006, 04:39:52 AM
BoksteR
Hi,
I want to connect 3 Midi inputs to 1 Midi output using a 3-pole 4-position rotary switch.
this way I can choose with one of the incoming midi signals will be routed out.
I cant understand the connection part of the switch.
This is my switch:
can anyone help me out? with a diagram or something...
10nX
b_rogers
if you cant find a diagram online, then do this
get a felt tip marker and your DMM. set the DMM for continuity, then find the 3 poles that show they are connected and mark those with a one. turn the switch to the next position, mark and repeat until you have found all four sets of three that connect.. as far as routing the midi i have no clue, but what i said will let you map out the switch.   hope that makes sense
Brent
homegrown, family raised couch potatoes. temperament unsurpassed.
http://electricladystaffs.com/
jmasciswannabe
#2
from my experiences the 3pole rotary switch works like this. If you are looking directly at the bottom of it, turn it so that the three center poles make a triangle. The top pole correlates with the two lugs directly above it and the lug next to each of these. Should be numbered like so, use the continuity checker on a dmm to make sure. In posiion one, all three poles connect to their "1" in position 2, all three poles connect to their "2" and so on.....
    3   2
4     '      1
on a side off-topic note - brent....thats a great looking dog! Is it a pit?
....the staircase had one too many steps
b_rogers
shes a american staffordshire terrier, which is the show counterpart of the APBT. bred more for looks to a standard and sound temperment. she won her class this weekend at her 3rd show. my wife and i show them. check out my site...
http://electricladykenels.tripod.com/
