one knob fuzz
Started by Crawf, February 18, 2006, 09:15:59 PM
Crawf
Hi, I am working on the one knob fuzz from the Dragonfly layouts, it shows two 1uf caps,ceramic i think but i only have electrolytic of that value which have a positive and negative side,could i use them and if so which way would the + and - sides go on the layout,thanks Crawf.
fixr1984
Yea you can use them. Put the + side of the one on the battery side facing up and the other
two should have the + side facing down. Hope that makes sense to you.
Crawf
Hi, Just wondering if anybody could suss this out, i`ve built the "one knob fuzz" and lo and behold, nothing! except when i hold the board and let my finger or thumb touch the soldered ends(just certain ones) the fuzz kicks in and depending how i move my thumb it gets louder, soon as i let go, back to no signal. I`ve changed the pot and omitted the switch to try and narrow the problem down but as a beginner i dont know where to look next,any clues anybody? thanks Crawf.
fixr1984
I would check all the connections and make sure they are good
then i would make sure everything is grounded properly.
8mileshigh
Crawf,
One thing I've learned to do is tug hard and wobble all of my wire solder joints when I'm finished, I almost always find poor solder joints and save myself an annoying trouble shooting session. You probably have a bad connection.
I built the L'il Devil one knobber in the Dragonfly folder and love it !  It's in his schematics folder.
8
Builts completed: Tweak-O, Fuzz Face Si and Ge, Rangemaster,Fuzzrite Si & Ge, Bazz Fuzz, L'il Devil Fuzz, Bosstone one knober, Bosstone Sustainer, Cream Pie, Kay Fuzztone. http://www.myspace.com/chrisdarlington
Crawf
Thanks,I`ll check it out tonight and let you know how i get on, cheers Crawf.
seanthomas46
It's an over used statement, nonetheless, it's what got me through my first few projects successfully.
CHECK YOUR WIRING!
If that's not the case, good luck man :icon_mrgreen:
Crawf
Hi again,Well after a few nights of hair pulling and checking everything over and over i noticed that i had misplaced some components so i replaced them and made sure they were in the correct positions and hey ho......fuzz, so thanks again for keeping me right(again!!!!!!!!!!)cheers Crawf.
