Moulded(Molded) input sockets
Started by Crawf, February 24, 2006, 02:30:35 PM
Crawf
Hi,After successfully building a few small projects i`ve started on another,i have previously used the metal type input jacks but i have acquired the plastic type(not switchcraft) with the solder lugs that run the length of the socket, three on the stereo and two on the mono, trouble is i`m stumped as how to wire them, are there any links or pics of the wiring so that i get an idea how its done, thanks Crawf.
phaeton
I don't know how to wire them, and I'm not saying this to sound like a *&^*&^ (honestly!)...
But if you stick a guitar cord into it, and do some continuity tests using your DMM between the other end of the cord and the solder pins, you might figure it out before someone can dig up a datasheet on it.
Otherwise, stick around, bc i bet someone's got this info handy ;)
Stark Raving Mad Scientist
Crawf
#2
Hi Thanks, I used my DMM and i think i`ve sussed it, easier that i thought, thanks phaeton.
Any pic or links would still be appreciated
