Simple mods link?
Started by janus, March 02, 2006, 11:13:04 AM
janus
Am I missing it? I want to try a tone/filter  knob on a fuzzface and can't find the simple mods page..can someone post the link?
thanks
brian
vanhansen
http://www.diystompboxes.com/cnews/mods.html
I agree it's not the easiest page to find since diystompboxes.com doesn't go to the old flash intro and then to http://www.diystompboxes.com/pedals/index2.html
I suggest you bookmark the link to index2.html.
Aron, can you add a link to the main index page to go to index2?  Or put the flash module in place?
Erik
janus
thanks I appreciate it. Gonna try this one but am confused as to where it hooks up to. would it be lug 2 of the Volume pot?
http://www.diystompboxes.com/pedals/lowpass.GIF
vanhansen
Try it hooked up to lug 3, the same one that the circuit output wires hooks to.  Then run a wire from volume lug 3 to the tone pot.  Basically, it would be wired up similar to a guitar volume/tone control but in this case, lug 3 and 2 are connected on the tone pot and lug 1 goes to ground with the cap in series.
Erik
janus
thanks I'll give it a try. I'm assuming I connect 2 and 3 of the tone pot and use it much like a variable resistor? and ground 1 in series. seems rather easy.
thanks again  for the help,
brian
vanhansen
That's exactly what it is, a variable resistor.  That's all a pot is anyway.  ;)
Good luck.  :)
Erik
janus
thanks..I'm newto this. ha! brian
