Jfet bias question
Started by ildar, March 11, 2006, 09:26:17 PM
ildar
Does the bias point of a jfet "drift" over time?
My Thunderchief was set properly at the drains when I built it  a bit more than a year ago. I never really used it much (though I love its sound), but last week I dug it out, popped in a new 9v, and it sounded farty and gatey. Do I need to rebias?
burnt fingers
Did you use tirmmers like the schematic suggests?  I'd double check those voltages again and look at the trimmers.
Scott
Rock and Roll does not take a vacation!!
www.rockguitarlife.com
My Music
  I seemed to notice that JFet circuits Drain node voltages "drifted' like you're saying.
  could be the trimpot 'moved' or something else changed...but at least what you've typed isn't a 'lone misnomer'...I know what you're talking about.
brett
Hi.
might be a poor solder, too.
For the extra few cents, sealed trimpots are a good investment.
cheers
Brett Robinson
ildar
I did use trimpots, the blue ones from Mouser.
The drains were all set at the time I built it, as I said. If one of the trimmers moved, would it affect the circuit like that? Since I didn't use it for quite some time, I'm wondering what could have changed?
trevize
it happened to me too :)
i realized that it was because i wasn't using a power supply adaptor but a battery. a bettery changes over time so the trim pot position should change over time.
bias your circuits with a good p.supply and always use that one! (or use a 78LXXX positive regulator in your circuits)
