Question About Mono 1/4" Jacks
Started by SYL, March 18, 2006, 06:52:31 AM
SYL
Hi, i'm a newbie. kinda...
will it be OK to use this type of 1/4" jack on stompboxes?
it has an integrated spst cutoff switch, with 3 lugs, it won't be a problem will it?
cause i will only ever be soldering to the tip and sleeve, right?
i hope this makes sense...
syndromet
I don't see why that wouldn't work. You need a  stereo-jack for the input, if you would like to use it as a power switch, though. But other than that I think they look just fine. But then again, I'm realy new to this, so if anyone tell you different, you should probably listen to them.... ;)
Have fun
Marius
My diy-site: www.syndromet.com
calpolyengineer
if it has a switch in it, I would think you could use it to turn the power on/off.
-Joe
pyrop
Hi guys,
On this one the switch is on the "tip" not on the "sleeve" so you could only use it as a standard mono output jack.
Although another use for this one is for eg: syndromet's ruby build as the external speaker jack so when you insert a plug it will disconnect the contact for the internal speaker.
pyrop ;D
SYL
#4
hey guys, thanks for the replys  :icon_smile:
it seems pyrop is right, when the plug is inserted the switch is disconnected...
interesting...
Connoisseur of Distortion
such jacks are best used on builds where you want a signal to either flow normally inside the circuit, or be interrupted by an external signal. Think CV on some builds, or direct out on an amplifier.
