schematic power supplies 18v
Started by ANDYEFFECT, March 30, 2006, 07:44:26 AM
ANDYEFFECT
does anybody have schematic PS for 18volts?
can I modify GGG ultra clean of 9 to 18v?
thankful.
André
kusi
hi,
have a look at the LM317 datasheet and calculate  r2a/b  for Ua=18V.  (www.google.de => " LM317 datasheet" )
whats the secondary-voltage of your transformer?
greetings KHE
ANDYEFFECT
Quote from: kusi on March 30, 2006, 09:22:51 AM
hi,
greetings KHE
yes, more which of the two resitores I change for smaller value? R2a or R2b (you look at schematic below)
http://www.generalguitargadgets.com/diagrams/ultra_clean_ps_sc.gif
thankful.
kusi
hi andy,
you have to increase the totally resistance of R2!
lets calculate it;
R1a and R1b are paralell, the totally resistance of this two is R1= 1/((1/R1a)+(1/R1b)) = 240.9 Ohm
R2a and Rab are parallel, the totally resistance of this two is R2= 1/((1/R2a)+(1/R2b)) = 1,545k Ohm
now, have a look at the datasheet; www.datasheetcatalog.com/ datasheets_pdf/L/M/3/1/LM317.shtml
Ua= Uref *(1+(R2/R1))*Iadj.*R2
Ua= Outputvoltage, you want 18V
Uref= Reference-voltage, 1,25V (=>datasheet)
R1= 240 Ohm
Iadj = ~0mA
R2 = ??
formula change over to R2:
R2= (Ua*R1)/Uref-R1 = (18V*240 Ohm)/1.25V -240 Ohm = 3216 Ohm
now, this is not a standart vaule, so you can use resistors in parallel to become a vaule neary 3.216kOhm, or you use
a 2,7k R wiht a 500 Ohm Trimm-pot in series to adjust Ua.
greetings KHE
jxoco
the input to the regulator circuit has to be over 18 volts.
so, the 12v transformer won't do...
kusi
that is logic, i think (and hope) andy know that... 8)
