Bad Stone Volume Drop
Started by lowstar, April 01, 2006, 04:12:40 AM
lowstar
hi everybody,
before i want to give my bad stone http://www.diystompboxes.com/smfforum/index.php?topic=43756.msg317204#msg317204 a "home in a box", i have to fix the volume drop. as i found the changing of the resistor on one of the op-amps as stated by someone else on this forum doesn´t work for me cause i don´t like the distortion and i´m pretty sure it changes the sound, i thought about putting a booster stage behind the circuit to go for unity gain. any suggestions what circuit i should use ? the three things that count for me here are:
absolute linearity/no sound coloration
doesn´t need to much boost (i just want unity gain and the volume drop is like 60-70% of original vol)
simplicity/parts count, i need to add this as an extra into the housing with the bad stone pcb (which is kinda big), so it should be a small layout
any suggestions ??
cheers,
lowstar
p.s. alex, does the dimension c also have a vol drop ??
effects built counter: stopped counting at 100
bluesdevil
I used the Strato Blaster to boost the volume in mine with great results. Just gotta remember to turn it down when you switch to "vibrato" mode.
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
