Vanishing point pots
Started by Bernardduur, March 30, 2006, 02:24:44 PM
Bernardduur
I am experimenting a bit with filters (the Super Filter (high pass / low pass / band pass)) is great! I want to add a sequecer, so I found the Vanishing Point.
I can't find any values of the used pots....... Doesn't it matter or is there a fixed value I overlooked.....
Am learning something new every day here
SquareLight | MySpace account
The Tone God
Quote from: The ArticleI left some part values off the schematic because it would be hard for me to recommend values in these places. For example the value of the stage pots depends on both the stage LED indicator as well as the LED in the optocoupler. This is something your going to have figure out. Some other values were given a range just as a suggestion.
;) I usualy find 50K-100K pots work well.
Andrew
Bernardduur
OK, great!
Anyone knows where to buy those small pots??
The Tone God
Are you talking those mini-pots / trimpots like those used in the Zvex sequencer series ? Digikey and Mouser both carry lines of them from various manufactures. The big problem with them is that most of them are log. Most people wire them in reverse to make them more tolerable to adjust.
Andrew
Bernardduur
Ah, OK....... Well, I have a lot of lin 100k pots here, so I just have to use a bigger enclosure ;)
spectraljulian
Quote from: The Tone God on March 30, 2006, 04:18:01 PM
Andrew
What part numer are they at mouser and can you get them in 250k?
The Tone God
Quote from: spectraljulian on March 31, 2006, 10:29:18 AM
I don't shop Mouser so I don't know on either account. Check their catalog/site.
Andrew
spectraljulian
well, do you know what company makes them?
NoFi
ALPS/Alpha but I'm using bourns pots on mine.  :)
spectraljulian
Mouser is the most confusing website ever.  So many choices, so little coherent descriptions.
What measurements should I be looking for?
http://www.mouser.com/?Ne=100&handler=data.listcategory&Ntt=*250k*%2b*audio*&terms=250k+audio&crc=false&N=170&Ns=SField
I hate mouser.
The Tone God
Try maybe 6mm or 9mm pots. Maybe even 12mm.
Andrew
jrem
Quote from: spectraljulian on April 01, 2006, 11:36:38 AM
I hate mouser.
mouser rocks.  you just need some time and patience.   Or try small bear or someone that will walk you though.
