Looking for a little help with Joe Davisson Shocktave.
Started by DavidS, October 15, 2005, 02:26:27 AM
cab42
Quackzed,
Thanks for tips. I was thinking about something like the pot instead of the 10K. I may end up actually knowing what I'm doing.
To use the pot as a variable resistor I need to connect one of the outer pins to the middle pin? I guess I can measure the resistance on the pot and replace with a fixed resistor.
One more question: It seems that it works for some people using the stock 10K resistor. Is it variations in the transistors that causes the need for biasing? Could I fix it by trying different 5089's? I have around 20.
Regards
Carsten
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
Quackzed
Yes,  (i think) its the hfe or gain that determins how you need to bias the transistor, from what i've learned here..so if you had a lower gain transistor in there (like me) you would most likely need to adjust the bias( bias determines gain...i think its collector resistor/emitter resistor that determines the gain of the transistorso naturally making the collector resistor a higher value will increase gain... 5089's are high gain low noise transistors that (usually) are pretty consistent gain from @600-900 or so??? so yeah... but just remember thathigh frequency content(treble) can create tracking issues... (i have a really bright strat type guitar with no tone controll that doesn't work as well with this box as my humbucker equipped guitar...)
if i were to adjust this pedal for THAT guitar i might add a cap to ground at the input(low pass filter) to roll off some highs and then increase the collector resistor of q2 to compensate for the gain loss off cutting highs...
i like how the attack seems sort of rubbery and analog(?) it's got a nice animated tone..not lifeless like a synth... caught myself trying to learn the solo from "fool in the rain" tho pagey used a mxr(blue box?)pedal on that; it's a similar tone and i can definately cop that cool tone with the shocktave! 8)
cab42
I got it working yesterday. It sounds as I had hoped for, not very different from RDV's sound sample.
It doesn't sound very good when the gain pot is maxed out, but if i turn it down a little and find the right mix setting it's great
Quackzed, Thanks for all your tips.
Regards
Carsten
Ripthorn
