Vanishing point problem
Started by Bernardduur, April 04, 2006, 07:43:43 AM
Bernardduur
OK, here's my problem;
I build a vanishing point; I used a philips HEF4017BP for the 4017 and a MC14093BCP for the 4093. I wired up a couple of LED's to the 4017's outputs to test my creation.
It does not work. When I turn on the power, the first LED (0) stays on burning, the rest does not come on. When I apply some pressure to the chip it sometimes work, when I touch the backside of the board it works........ when I release it stops working and the first LED (0) stays on.
I checked a lot; I use an IC socket and measured resistance for each leg....... nothing yet.
Any ideas?
Am learning something new every day here
SquareLight | MySpace account
FcKw
Hi,
i just had the same problem, when the reset-pin of my CD4022 was connected to nothing. I just put a 1k Resistor from pin 15 (reset) to ground to get a well-defined state and it works. It should be the same pin on the CD4017, perhaps this helps.
(sry for my german-english ;D)
FcKw
Bernardduur
#2
Ah, thanks.... that is true, it is not connected. I will try!
Ach, Du kannst auch mal Deutsch sprachen;
Edit: Yep, it works like a charm right now!
The Tone God
There is a post that has some updates, including addressing your issue, I have not included on the site yet in this thread:
http://www.diystompboxes.com/smfforum/index.php?topic=28396.0
Andrew
Bernardduur
I already added those to my circuit......
still the ticking irritates me ;)
