Negative Ground Sola Sound Tone Bender MkII - need some expert help!
Started by Telecopter, April 05, 2006, 09:01:48 PM
Telecopter
Hello everyone. It has been a while since I've been on here! Can someone tell me if this schematic that I did is correct for a PNP negative ground version of the sola sound mkll tonebender? When everything is plugged in, it does indeed work, but even with the alteration of changing the 100k (originally) resistor off of the Q1 transistor down to 10k, there is still so much fuzz that even with the fuzz knob all the way down, it is still quite heavy. Do I maybe need to put a larger value pot in for the attack to help tame the fuzz a bit?
Lastly, below is another version of it - I've noticed that the only big difference appears to be where the C5 transistor is compared to my schematic (my "C5" is at the top left of the page). Which is the correct place for C5 to reside in the circuit? Thanks for any help you guys can offer!
amz-fx
Quote from: Telecopter on April 05, 2006, 09:01:48 PM
Electrically they are at the same place....  no difference.
-Jack
Telecopter
Thanks a million, Jack - good to know everything is ok with my schematic!
