overload gigboard with cry baby
Started by Loggie, April 10, 2006, 02:06:48 PM
Loggie
I've modded gcb95 with 3pdt switch and led blue (high intensity) but if wah is off the gigboard go in overload.
why? ???
scumbag
Did you wire a resistor in series with the LED? Sounds like the LED is sucking too much power.
Maybe you need a bigger resistor if you already have one. I have a 1k5 in mine and I'm sure I could go up to around 3k and still keep the LED fairly bright.
Amateur Experamentalist
