Could this thing work?
Started by bancika, April 16, 2006, 06:14:42 AM
bancika
I'm thinking about making something like POG just simpler. Can this idea work: make 4 channel mixer, dry signal goes to first, octave down (which circuit?) second, octave up (which cirtcuit?) to third and second octave up in serial with previous to last channel.
Tnx
RaceDriver205
Id say yes, try it and tell us!
bancika
Ok, which circuits (simple if possible) you recommend?
trevize
Marcos - Munky
Tim Escobedo's Pushme Pullyou is a great and simple octave up.
Paul Perry (Frostwave)
Well, it won't be a POG, because so far as I can see, the POG works with chords (being DSP, I suspect). At least that is what it sounds like to me. If I am wrong, doubtless I will be corrected!
nelson
Why not build the Pearl octaver? It has 1 octave up + 1 and two octaves down.
By all accounts its one of the best analog octavers around.
My project site
Winner of Mar 2009 FX-X
bancika
Do you have layout for Pearl?
I think this idea could be interesting cause I could blend different octaves together (like satriani does with POG on his last album)
