A couple of questions
Started by Crawf, April 15, 2006, 05:00:48 PM
Crawf
Hi,I was wondering about a couple of things, I have built a Tripple Fuzz from the Dragonfly Layout Gallery,can i add a power supply jack to accept a boss style PSU? secondly can i adapt perfboard layouts to stripboard? cheers Crawf.
boogietube
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
delbowski
Quote from: Crawf on April 15, 2006, 05:00:48 PM
hi...
yes you can adapt it to stripboard.  you will have to break the traces of the strip if you have components in the same row that shouldn't connect.  some use a tiny drill bit to scratch a break in the trace, or maybe an exacto knife.  in essence, you're making the stripboard into perfboard.  hope that helps...
del
Crawf
Thanks for your help,cheers Crawf.
