Tone pot modifications
Started by Single Coil, April 25, 2006, 12:35:30 PM
Single Coil
It seems that the several pedals that I want to build all use tone pots or drive pots with different ranges. Would it be reasonable to load up on 100k pots and modify each as needed by adding resisters or additional caps to the pots to taylor each pot to a given schematic? Adding the appropriate resistor can turn a 100k pot into 250k or 1M if a guy knows what he's doing? Is there a reference page for making these tone pot mods?
Thank you.
Muchos Gracias.
Merci Beaucoup.
Phorhas
Electron Pusher
Single Coil
