Echo Park - making it quieter.
Started by jbm222, May 11, 2006, 11:26:56 PM
jbm222
Is there a good place in the echo park to add a capacitor or two to make it quieter when powered on DC?
no one ever
a small inductor somewhere will help
(chk chk chk)
  I havne't to notice a peep of noise out of my EP..maybe I'm not listening hard enough for it.
bwanasonic
Quote from: jbm222 on May 11, 2006, 11:26:56 PM
Are you using the Line 6 supply? Search the archives here, as there is a trick (posted by *Mr. Huge*) powering the EP on that effects noise. I use the EP in the loop of my amp, and I can usually gain stage things so noise is not a problem. I use the Line 6 supply. There is also an issue with 1st gen EPs, so if you have one of the early ones, it may be noisier than others. They may offer an upgrade, but I'm not sure. Again, search here, as this has come up before.
Kerry M
