2N2614 Pinout
Started by alderbody, May 03, 2006, 03:24:12 AM
alderbody
Does anyone know the pinout of the 2N2614 PNP Ge transistors?
datasheet archives don't seem to have it in their db's.
thanks
  if your DMM has an Hfe Checker...
  I use a socket with 'legs' added, and put that in the HFe socket, that way I can make contact with the DMM's deep seated contacts...some transistors just arent' 'leggy' enough to reach them....
  Then just stick 'em in everywhich way until you get a 'reasonable' Hfe reading...for finding transistor pinouts it's quick, but doesn't do any 'leakage math'.
  I got used to and use the 'arrow' method, the base on all my Ge transistors, in relation to the E/C pins, forms an 'arrow tip', and that tip points toward output.
  Best bet is check and verify your pinouts on Ge transistors...I used to like to use even a 2n3906 or something to get 'normal gating' sounds...pre-testing the circuit to see if some kinda wrong bias [but sorta close, close like Si where Ge should be...DMM bias readings] that way I get a circuit to 'pop' [kind of like a car sputtering...at least you know combustion 'wants' to take place]...THen stick the precocious Ge's in there...I started doing this when I noticed I'd somehow turned good Ge transistors into fried Ge Transistors.
alderbody
Caution is always required with Ge devices. Especially if they are as rare as the 2N2614...
I already did what you suggested with the DMM, but since it's a little crappy and it doen't seem to like all transistors,
i can't get any reasonable readings.
that's why i asked for a straight answer.
thanks anyway!   ;)
  did you try looking up the data sheet?
  ...lol...yer Welcome anyway
lovric
  There's that 'arrow'...the tip is marked '2', and points most Ge's to the right orientation if pointing towards the output [abstract...you can't see it when it's on/in the board].
  But good that you're finding that out for certain before installing and possibly reverse polarizing it!!!
  For the first time I've got some CV7112's [iirc] that have a red dot indicating collector, first time I've had Ge's that didn't have the base offset where it exits the body.
alderbody
Thanks so much for your help guys!!!
