orange squeeze + variable output, voltages?
Started by dachshund, May 17, 2006, 02:25:40 PM
dachshund
I'm building this circuit,
http://www.generalguitargadgets.com/diagrams/orangesqueezer_marks_variable.gif
Does anyone know the expected DC voltages around the 2 opamps?
thanks.
Not sure what you mean by "around the op-amps".  Certainly pin 5 should be sitting around 4.5v with a fresh battery, and pin 3 should be sitting a little higher than that.
johngreene
Quote from: Mark Hammer on May 17, 2006, 03:33:18 PM
Not in that schematic. Pin 5 may be connected to a voltage divider with 2 330k's but they are DC coupled to a 10k pot that goes to ground! Which probably also forward biases the diode, etc. Mistake in the schematic perhaps?
--john
dachshund
Yes, the voltages on the pins of the IC. So far the thing barks, at best  :icon_eek:
This is the orange squeezer plus a second stage that Mark Hammer added.
It's possible I've got the wrong FETs. I have NTE457 which are supposed to be equivalent to the 5457... but that could be incorrect.
Quote from: johngreene on May 17, 2006, 04:23:51 PM
--john
More like a mistake in the conception, heh, heh! :icon_wink:  I got lazy and just assumed that C6 would do all my dirty work for me.  Probably another cap should go between R13 and the R15/R16 junction, then?
johngreene
Quote from: Mark Hammer on May 17, 2006, 04:56:58 PM
--john
That would do the trick.
--john
dachshund
johngreene
Quote from: dachshund on May 17, 2006, 06:53:48 PM
Another 4.7u there?
That should be fine, + side toward the opamp Pin5.
--john
